TRCM
- Newport News,VA
These look awesome, but I'd be concerned about the area where mud can build up and would not be easily washed out from the pockets formed by under the rails by the stock pinch weld
so if someone had a decently large dent in the rear portion of one of their rockers, how much would it affect the installation, would said dent need to be pulled?
Will these still install correctly with the RE long arm belly pan where the side brackets bolt to the pinch weld?
Hard to say without seeing a picture. Might have to do a crude job of pulling out the rocker before installation if it does not fit right.
Right off our product description:
*Those with Rubicon Express kits will need to remove the pinch seam gusset plates.
What about a Clayton Suspension lift?
Is there any thoughts or plans in the works on making this same style slider for KJ/WJ/TJ in the future? I see right now the only models getting these are the XJ and JK. I would LOVE to have a set of these for my WJ! Too bad my XJ rockers are halfway gone on both sides, or I would have these for it.
Would these sliders with T&J frame stiffeners?
