cruiser54
- Prescott, Az
Ken, there was a recall on the ratchets. Check with your dealer. Can't remember which years but you have motivated me to check on mine.
I'll have to do so.
I just googled "comanche park ratchet recall" and this thread is already the #1 result :roflmao:
I just helped a friend with an 87 YJ a while ago, it came in with the horrible BBD e-carb + Ford computer and more vacuum lines than the space shuttle. It'd also been "improved" by several previous owners and the vacuum line setup resulted in me ripping most of my hair out trying to figure it out. Finally we fixed it by putting a weber on it and bypassing the computer completely, it now runs way better and the exhaust smells nowhere near as bad.
Who ever thought combining computers and carbs was a good idea? It is basically the worst of both worlds!
It still has no real power and he wants a 5speed instead of the factory auto (yep, it has a column shifted auto... what?!) so he is collecting parts to do a 4.0/ax15/np231/sye/8.25 swap, we are going to build a custom harness for it based off a 96 XJ one most likely. Already put a full custom dash harness in it to eliminate the ratsnest of terrible wiring (factory and non factory - it had been "upgraded" with a CJ7 dash and instruments, none of which worked and all of which were wired in truly inventive ways...)
Coolest thing I did was install a few MOPAR fuel injection systems on the 87 to 91 Yj's with the 4.2 when new carbs from Chrysler dried up for the YJ..... You never saw a 4.2 YJ run so good![]()
mine? LDS or LDT (forget which, the stock one) 465. It's currently in need of a head gasket replacement and acting as a storage locker for two V8/5spd/4x4 drivetrains, six 46" tires, five or six dana 60s, two or three 44s, and a few other random axles. Holds the ground down quite nicely.What engine in your M54?
LOL...yea, I have had my butt kicked a few time on CJ's and 87 to 91 YJ's with carbs ....... You can bypass the Feedback PCM for the carb and ignition, but retain the stock Ford ignition so it works independent and use non feedback carb....... Coolest thing I did was install a few MOPAR fuel injection systems on the 87 to 91 Yj's with the 4.2 when new carbs from Chrysler dried up for the YJ..... You never saw a 4.2 YJ run so goodIt was based om 1995 XJ 4.0 fuel injection and used the same PCM part number..... it ran the crank sensor off the front harmonic pulley..... the whole kit was pretty much bolt on and you got 95 diagnostics..it was $1800 for the kit, but that was awhile ago......
Still the worst for vac lines all over the place I can recall was early 80's Mustang with a 4 cyl and carb.......
His YJ will be nice with all the 96 XJ stuff and parts he has been collectiing![]()
That's what my M543A1 had in it. Kind of a slug but sure fun off-road.
Obviously yours is a cargo truck. LOL.
I did one of those conversions for a customer. 4.2 with fuel injection. Woohoo. Easy job, too.
