Anyone else experience this? I have a 96 XJ. I've tried all the door switches and headlamp switches, but no luck. I can pull the fuse and they all go off from there. Any tips to help? Thanks.
This response was probably in one of the threads Lou noted, but I had this problem on my 96 and found that the rear passenger side door switch had gotten "smooshed" at some point. When I closed the switch manually it worked, so I JB Welded a coin into the striker area of the door...and it works.
My 98's would not go off due to a 'feature', if you pushed the rear cargo light in so it clicked the lights would stay on. Must have bumped it with my head while I was putting in the OEM cargo mat and did not notice. Wasted 2 or 3 hours, wife found the 'problem' in the owners manual. :rattle:
