- Near Rochester NY
I am installing an ARB Air Locker and 4.56 gears in a 1987 XJ front axle with the non-disco Dana 30.
Question #1
I have the ARB instructions rev. 08/04/03. Page 12 of these instructions has a section titled "Insuring Adequate Oil Drainage". The diagram on this page is of a Dana 44. However, it looks like my Dana 30 also only has the slots at the top corners of the bearing thrust surface. Does this caution also apply to my Dana 30?
The note on the right side of the diagram shows a slot in the "correct location", at the bottom of the bearing bore. The note on the left side shows a "drainage hole drilled at the lower side of the tube to improve drainage".
Should I drill a hole, or get the die grinder out and cut a slot?
Question #2
I have a 2000 XJ front axle (D30 LP) that has a bent tube and a LCA bracket sheared off. The axle shafts are good. Will these axles bolt into my '87 housing and use the '87 brakes?
TIA
MoFo
Question #1
Question #2
TIA
MoFo
