blondejoncherokee
- sacramento
dont bother or waste your time with a selectable locker, just get a grizzly or a detroit.
don't bother or waste your time with a selectable locker, just get a grizzly or a detroit.
dont go with an elocker, they're weak. i have one in my d44 and it's been repaired twice so far in a short period of time. plus eaton is absolutely crap when it comes to customer service. i have a grizzly in the front and i like that so far, so if i ever get another locker i may consider the zip.
That sounds good to me. Where do I find a free HP housing? Housing means no axles, and gears, or is that just the pumpkin? Good time to trus too I guess and if there are no axles then go chromo's at that time too?
The passenger side upper control arm mount is a weak link and has been known to tear off as a result of hard use. If you plate it the front side, it boxes it in and makes it significantly stronger.
Well that sounds easy to do. Thank you.
ya i ripped my pass side uca off on the rubicon last year. luckily i have a 4 link so just drove home as a 3 link.
I have four link too right? 2 UCA and 2 LCA with a track bar. Does this mean I have a 5 link? :eeks1:
4 link with pan hard
"pan hard" should I be offended?eace:
OK so what is a pan hard?
