IN - 91 XJ 10" Lift 37" SSR
rwilde
1991 JEEP CHEROKEE LAREDO
4.0L Six cylinder Engine 212,000 miles
K&N Cone Air Filter
Crank position sensor
MSD 6 Ignition Box
MSD Coil
MSD Plug wires
NGK Spark plugs
GDI 3 Core Radiator
Fuel Pump
Valve cover gasket replaced
Rear main seal replaced
Dynomax Cat Back Exhaust
M.O.R.E. Motor Mounts
Battery
5 Speed manual Transmission
Clutch Master and Slave cylinder replaced
NP231 Transfer Case
JB Slip Yoke Eliminator
Ford 8.8 Rear Axle
Mini Spool
Motive 4.88 gears
Tom Woods CV Driveshaft
Jegs Aluminum rear cover
Disc brakes, All new calipers, pads, and hardware
Dana 30 Front Axle
Mini Locker
PosiLok cable actuating front axle
Custom WJ Steering Knuckles
WJ Dual caliper pistons and Rotors
Steering
Custom steering links from Spider Trax
Skyjacker Extreme drop Pitman Arm
Rancho RS5000 Steering stabilizer (not installed)
Rusty’s Offroad Steering Box Brace
Custom Track Bar from Spider Trax
Suspension Front
ACOS adjustable coil spring spacers
Pro Comp front coil springs
Teraflex adjustable upper and lower control arms
Rancho RS9000 shocks
Suspension Rear
Big Offroad 8” Leaf Springs
Teraflex 1.5’ lift shackles
Body
98+ Style front fenders
98+ Style front Header panel
98+ Style fender flares
Body is very Solid with no rust
Wheels and Tires
American Eagle 589 15x10 3.75” backspacing wheels
37/12.5R15 Super Swamper SSR Tires
What needs finished
The front axle gears need changed to 4.88 (they are still stock)
Steering stabilizer needs installed
Fender flares, grille, and bumper end caps need installed
Could use a paint job due to the clear coat coming off like many Jeeps I’ve seen.
Speedometer bounces around (might need new sensor)
Interior has some stains but not torn up or broken
Jeep only driven 200 miles since assembled, worked on it for a long time and have now lost interest in this project.
Many stock Items that can be go with the jeep. Front fenders, Front header, Rear Axle, stock wheels and tires, and many more stock parts.
$10,000 invested
$6,000 in receipts that I can find
Sell for $5,000 OBO
Email
Well I could make the pictures come up in the test forum but now I am unable to get the pictures to come up so you will have to follow the links.
