POLAR_JEEP_04
- Ohio
My "Chicago" grinder and sawzal were loud and got rained on and beat up but they finally died
I use craftsmen and duralast tools. I get tape, cutting and grinding wheels, and random stuff like hose clamps and fuses at HF
call rourk for grinding /cuttoff wheels. They are better than anything I have bought from HF, HD or lowes.....
Who is rourk? Is it a company?
I buy cheap stuff like wire loom, zip ties etc from HF, but as far as tools, not much of anything that I woudl depend on for fixing something in the field...I view most as disposable (like Josh said about the grinder). I picked up some tire spoons.....they did not last one mounting.
I have ran into a few hose clamps that strip out as soon as you snug them down.
I usually stock up on fuses and relays when I hit the junkyard.
This guy not sure why he is not listed on the sponsors page (pretty sure he still is?)?
http://www.naxja.org/forum/showthread.php?t=1083790
He donated to the giveawayxj build with supplies but I don't recall if he was a sponsor for 2013 sponsorship program. There were two different things to donate towards.
mac 'Harbor freight grinding discs are decent...only have had a couple cut off wheels self destruct' gyvr
His name is still blue so I figured he was a sponsor.
I don't use HF cutoff wheels, they have cancer warnings on them. I have enough carcinogens in my lungs already. I use Heleta cutoffs, get em in bulk for 53 cents each and they seem to do pretty well.
With enough lube on the bead I mounted a tire by hand with HF spoons... went pretty smoothly in fact. Went horribly last time I tried without enough lube, I bent the damn spoons then and almost gave them away.
