- Michigan
Got lights.
That could start a whole multipage tangent on idiot customers. I'm with ya, I worked at Advance for ~2 years and got the whole range of customers. My favorite is the "all Chevy 350s are the same" people.
The motor is the same, the accessory brackets are different, the manifolds will bolt up, if the TJ is coil on plug (I don't think it is in 99) then some brackets will have to be made to hold the coil pack rail thingy.
87 "helped his neighbor do 4.0 swap in a 97 TJ" manche
edit: and the water pump was different too I think. We basically stripped his motor down to bare longblock, swapped in an XJ motor and bolted all his TJ crap to it.
well aren't they?
87 "same displacement" manche
Present and accounted for.
:wave:
Oh great, Flex is hitting on my sister on facebook. he's gonna have more then one missing tooth when I'm done with him...
don't get used to it. it will do it again it is still a ford after all.17* today and the PSD did me good....it is regaining its trust with me. good thing bc WF is right around the corner!
I own one and still not a believer :doh:
hush with that talk, it can hear you![]()
Would that be Lindsay??
Yea....I can understand where Flex is coming from.
Rev
