- Columbus, In
Took the jeep on its first run since the chop this weekend:
You have a sick obsession with mud Travis.
Is this place right off of Rt45 with a big "Mud Bog" sign in orange spray bomb?Took the jeep on its first run since the chop this weekend:
Around here they use old buses to haul melons from the fields to market. They cut the window frames out and have one big opening to throw the melons in.
Started re-wiring the trailer today. It worked when we got it but, it wasn't wired up very well at all. Got all of the new lights mounted, and new wire ran. Hope to solider all the connections and brake wires tomarrow.
No more wire nuts!![]()
Hey, wanna come rewire mine when you're done? It's done pretty half-assed, right before the Redbird trip I discovered that the rough, plasma burnt holes in the frame were tearing up the wires pretty bad.
You get a kit for all of the wiring or do you have a hookup for that?. Somewhere that you can bill it as R&D?
You get all the wiring in and I can solder them Friday night. I may not be good at much but that's one thing I can do well. I figure I can help you out since there will be a lot of stuff of mine in your truck bed this weekend.![]()
Yeah, but can he solder WELL?
Soldering is an acquired skill, just like welding... chinese child laborers can't do either!
Ken 'been an electronics nerd with a soldering iron for 15 years now" Stein
:roflmao: fair enough :anon:Hey, STFU!
I'm pickin' on Aaron here!
:spin1:
you're really comparing him to a blind one-armed monkey though!? That's just harsh!
Actually, soldered connections are somewhat brittle. An easier option for a lotta folks are filled crimp style butt connectors that are covered in heatshrink tubing. A bit pricy, but crimp and heat 'em up with a cigarette lighter, and done.
Something like these little beasties: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=095-910
Yes, a crimper is mandatory, pliers will not make a satisfactory crimp.
