poorboy87
- Linton Indiana
It's a 92 Laredo with power everything and leather. Has no engine in it but it came with one that was knocking. So I need to figure out what I'm going to do with the engine.
I bet Dan would cut you a good deal on a 7 cylinder hemi![]()
You can loosen the lash on the gear. There is a nut and set screw in the top of it. I'd mark a line on all of it loosen the nut and give the center screw 1/4 turn. Then tighten the nut. Usually a 13 or 15 mm jam nut.
That could be an alignment issue. Too little caster can cause that also.
I have adjusted the castor twice now, once I added a bunch.....no luck. It doesn't help that the front sway bar is off right now because the mounts had to be cut off the axle to make way for the steering......This will be fixed soon, hopefully before I guard rail it.
put a sway bar on it and see how it handles.
makes a difference on something that's coils all the way around.
mac 'put my top back on last night...now it's 80 degrees today' gyvr
That's the plan.....and my top is off.
