BRIANHO13
<- Yum Chocolate
- Spring, TX
Because you're always telling them "not with that attitude"?
Damn right.
I've got the same pile at home.
What are you using for your soft lines?
I am going to attempt to use my xj flex line and then use the soft lines from the liberty and put a new tube nut and flare it. I haven't looked to see if it will work yet.
I've also hear rear wj hoses will work if that plan falls through then it'll be two RH explorer lines. Ill post up when I get it lined out
No pun intended
No pun intended
Sean Ryan will buy my truck and I will meet him in Fort so I can drink with Mac to celebrate the deal.Sean Ryan just buy my truck and trailer so I can get a one ton and wedge and tow three eor jeeps at a time.
All i did for mine was use the liberty hard line and just cut it down and reflared it to the length i needed. Worked out just fine. Still using the liberty soft lines as well.
No I didn't put parking brakes on mine. I tried to use as much from the liberty as I could.That's the plan I had in mind.
Did you put a parking brake setup on yours? I have all the crap but I need hardware and shoes. Did you use the liberty cables?
5, 7, or 8, I forget. Probably 5 on a 2000.
That's on the sensor power bus wire, you'll see 0 volts on the ground wire (of course) and an alternating/pulse signal on the signal pin that you will only be able to read with an oscilloscope.
Wow, Did the shocks need replaced anyway? You have rear bumpstops? Yeah, I found the cracked LCA axle mount unloading from trailer in daylight. I wonder if there is anything else? I am going to pull/pic a parts on Friday looking for some coils......finally cleaned the jeep from the crawl. somehow i bent both rear shackles. kind of surprised those bent before the mounts.
