POLAR_JEEP_04
- Ohio
Doesn't your "meds" tell you to call a doctor if you have to wack it that long?
Polar 'blue pill' Jeep
If someone is looking for a nice diesel tow rig, I can hook them up....
2002 F250 149,000 miles.
http://rockford.craigslist.org/cto/4547005755.html
My truck, most everyone has seen it at winterfest.
The price for amember is very negotiable.
Even comes with a RHXJ sticker!
I think my spring hangers were nonexistent
Someone should teach the guy that did that ad how to take photos...
mac '' gyvr
It is fuse #22 in the pdc that was blowing. It is on a 2000 xj. I found a wire tonight that goes to the fuel pump that had a bad spot in it and I'm thinking was grounding out against the fuel rail. Now I believe it's got a bad cam shaft sensor as it popped a po340 code.
You know, I had a random thought about the field coil wire last night on the drive home.Almost never the ECU. Sometimes, but almost never.
What year and which 15A fuse?
Stuff the ASD relay fuse powers: ignition coil, alt field coil, injectors, O2 sensor heaters, part of the ECU, and a number of other things.
I've got the wiring diagrams in front of me, pretty wide experience with jeep harness troubleshooting, and have done custom/stripped down/swap harnesses to put HO 4.0s into other things, so if you can tell me what fuse is popping, I can probably pinpoint a trouble spot on that circuit or at least get you started in the right direction.
wienerbox could retrieve that if it is not running.
Try 98ish passenger side explorer 8.8 lines.
I must also find a nice local Loan Shark like Mr. Mcflipcointoothpickinmouth.
Sean, you shouldn't have a problem selling that truck!
https://secondnational.com/Pages/default.aspx
^ that bank does good rates on older trucks.
mac 'instead of jacked up interest on an older truck' gyvr
The other Sean, you goon! The one with the truck you need a loan shark for!Selling what truck?
The other Sean, you goon! The one with the truck you need a loan shark for!![]()
Lol NM
