Important
You forgot about the DDM (Drivers door module) and the PDM (Passenger door module).
The power lock control circuitry is in the PDM. The DDM provides a path to ground to the signal the PDM to lock/unlock the doors.
What is it doing exactly?
The locks are stuck trying to lock with the lock motors steadily pushing to lock. Draining the battery and making it almost impossible to unlock and open the rear doors.
Can a Verizon 4g phone be used on us cellular?
XT912 with CyanogenMod 11 (Android 4.4.2).
Has a sim card slot.
if the radio in it works on the correct frequencies, yes.
SIM card contains the number it uses to get on the network, so a US cellular one in there and verizon won't know.
Make sure it isn't carrier locked. I forget if cdma phones can do that.
Wouldn't the aftermarket ROM take care of any software locks Verizon/Motorola may have had on it?
I don't know what they do hardware wise...
Guess I can just try throwing my sisters sim card in it when I get to Iowa. Verizon is pretty much non existent there.
actually you'd be surprised. i'm not sure what it is like up by jed, but i never had issues with verizon. us cellular is the best provider to have in iowa, but verizon is in a close second.
DO NOT get att or sprint...you may as well not have a phone at that point
So transmission people... Does anyone think a NV3500 with a good clutch would survive behind my 5.9L?
The coloradan is right, nv3500 is rated for 300 ft lbs... same as the nv3550 and ax15.
With your motor and right foot? Glass.
Re: Re: Important
It must just suck in northern Iowa then.
I get 2 bars and 3g in Chapin if im lucky. Pretty much nothing in the basement.
Dropped calls/no service in the 5 mi between Hampton and chapin, decent service in Hampton SOMETIMES, and full 4g in Mason city.
Jed was getting very irritated with my phone during harvest. Communication between us when I am in the combine and he is 20mi away is very important. I kept dropping and missing calls all the time or had no service at all in the field.
The ideal situation would be if us cellular would release their grasp a little and let Verizon roam on their network since there are a FEW places that Verizon gets better service.
Yeah but nv4500s only have to be built once.
Seriously though look at the mantrans out of a deuce or 5ton if you want cheap, giant, bulletproofness. If you can find a way to put a standard sae bh pattern on a 5.9, you can stick one behind your shit with ease. Good luck having a right leg or a trans tunnel though.
By five nine I assume you mean 360 not 359
If that's the Case, you won't need much building on that 46 to handle that Magnums power.
I wish I could agree with that. My 360 destroyed a fresh jasper 46 in one trip.
Re: Re: Important
I assume that they used the 5.9 in three quarter tons.
I'd be looking for one of those. That or an old school 4 speed.
The bigger problem is making zj computers happy with something non electronic. Can you swap vss stuff into a NP 240 series case ?
