- bourbonnais IL
6 years ago i got hitched, she is a good woman for putting up with me
I need a beer.
T's daughters bday is today and theres 10 screaming 11 year old girls here for her party.
I survived.
Never looked forward to going to work so much as I did this morning.
Steve,
They are an E12 reverse torx. They are easiest to get to with a shit load of extensions and a wobbleer (sp?). Undo your rear drive shaft from the t-case, support the t-case w/ a jack under the cross member and take out the cross member bolts, then let the jack down a bit to give you enough room to get your socket, extensions and wobbler up in there. If you have another person it is helpful to have them hold pressure on that socket so it does not slip off and strip the edges..then your are F'd in the A!! I have swapped out plenty of motors and that is what I always do to get the two parted. You dp have the flywheel unbolted, right? I will PM you my number if you have any more questions. :thumbup:
I don't remember the size but they are the inverted torx, and you have to have about 8 feet of extensions and you have to come from behind the crossmember to get to them. Or you may be able to get the engine hoist on it and take the motor mounts loose and let the engine drop a few inches to get in there.
Parakeet
I always pulled head prior to taking out motor. Never had one of those bar deals so hooked chains to old head bolts. You can get to them with a wrench, with the head off.
the last motor I pulled I cut holes in the tunnel.
of course it was on its way to the scrap yard.![]()
