kmanxj5050
- Reed City Michigan
Da vikes are failing already this year! How the fawk did they lead the whole game then lose in the last few minutes.
bear down!
I wouldn't ditch the prop valve, personally. I don't want equal pressure front & rear. I've also got a Wilwood adjustable prop valve plumbed in on my non-ABS '94.
If your brakes are sinking to the floor, you've got a leak. And if you're not losing fluid, I'd suspect the master cylinder itself is leaking and needs to be replaced. In any event, that does need to be fixed.
