YELLAHEEP
- Littleton, Colorado
Another thing when doing the front spacers........
Disconnect the track bar at the axle - remove the bolt and pull the bar out of the mount. This allows the axle to drop much farther down and you "shouldn't" need to do much prying to get the coils out. Definitely disconnect the shocks (easier to disco them from the bottom than the top) and be sure to watch your brake lines to ensure you don't pull on them too much. It wouldn't be a bad to go ahead and relocate the hard line at this time anyway if you plan on running sway bar disconnects off road.
Here's a link to how to re-locate the hard brake lines for the front: (Scroll about half-way down)
http://www.lunghd.com/Tech_Articles/Suspension_Steering_Axles_and_Brakes/Budget_Lift.htm
