- San Diego, CA
When I did mine, I lined up using the marks on the harmonic balancer, and used a probe in the spark plug hole to make sure I was at #1 TDC instead of #6. (that took me a minute to get right)
Cruiser's tip says to line up with the trailing edge of the rotor departing the #1 terminal (the other thing I had to do twice) - if that's not working for you I think you could try bringing it back a bit (so you have more overlap between the rotor and #1 terminal).
