- San Diego, CA
I think you can rule fuel out, I just wanted to make sure you weren't pushing 60# from a 97+ pump through huge injectors.
Is your valve cover rear CCV orifice clogged or plugged (should be vacuum from the intake)? Is the front valve cover orifice running to the airbox properly (should be a larger tube connected to the rear of the airbox)?
I ran into some intermittent misfiring/dying at idle issues before I reindexed my distributor...might be worth a shot.
