Lawn Cher' said:
Back to the matter at hand... now that you've started, how long until you are finished?
Axles go under the truck this weekend. Some help from my brother and dad.
Here's my timeline.
Tonight: Axle perches and gear setup
Tomorrow: Complete new rear brakes. Only part I need to get is the rubber hose, and I'm trying to find an extended one. Looking at the 96 Dak hose, but I can't find anyone with it in stock to compare with mine. Only thing that will need to be pulled from my rear axle is the brake drums.
Friday: put the MJ up on jackstands after work. Pull wheels, brake drums and front rotors and wheel bearings. Transfer brake parts and wheel bearings over to new axles.
Saturday morning: Start pulling axles, Insert AAL and new coils
Sunday: Put new axles in.
Memorial day: Align the front a la GoJeep, go play (hopefully)
Things that are already done: Axles are painted, JKS discos installed on front axle, old unit bearings off 97 axle.
Things I need to get yet: Strap kit for U joints. New U bolts for rear axle, new hard lines for rear axle, I've got all the rest of the brake components, and they're assembled on the backing plate already.
