Ok. After 14 hours of work the truck is lifted, but Mark's craziness with the front brakes set me back today.
here's the run down.
One broken upper rear shock mount stud. Replaced with a bolt through the frame.
Both LCA's had to be cut from the frame with a sawzall, it really sucks when melted rubber and metal drops all over your face.
Ended up reusing the 97 Bearings, my bearings wouldn't fit. The bearing was too long into the knuckle and hit the tone ring on the shaft.
Got new 97 rotors and calipers, need the old style calipers, found this out after 3 trips to the parts store for the right pads...
Things that need doing:
All rear brake hardware, right now it's just empty drums.
Front calipers.
Bleed brakes.
Hook up Trackbar.
Do ghetto Go.Jeep alignment.
Fill diffs with oil.
Take it for a test drive.
I took pictures, need to find te memory card reader.
the Mj certainly sits taller now, rocker panel is about mid-thigh for me, gonna have to jump to get in.
