Michael McAtee
- Redding, CA
I am also assuming that. I'm currently looking for a zj steer box to port.(zj's have a dropped pitman arm...i think)
Michael McAtee said:I am also assuming that. I'm currently looking for a zj steer box to port.(zj's have a dropped pitman arm...i think)
Michael McAtee said:i'm thinking of mabey using poly bushings for my hydro assist ram
Dan Turner said:Brett, if the ram still has more stroke when the steering hits the stops, will the pressure relief valve in the pump stop sending pressure to the ram, so it won't tear the knuckles off? How's that for a run-on sentence??
I agree, and you can't do a ram without heims on an inverted Y steering, you need a knuckle-to-knuckle tie-rod.offroadman83 said:For the guys wanting to run this on the stock steering and stock knuckles------------I would not do it. The rams force would be way to much for the crappy stock tie rod and knuckles on the dana turdie======Kyle
I took my time doing the box and that was about 2 hours. Then just mount the ram, which depending on how you do that could take 20 minutes or a few hours. We need CRASH to post pics of his, he did it a few weeks ago with the same ram as me but he put heims on the ends and did a very nice job, especially with his *bling* tie-rod clamp.cracker said:I so want to do this but I need to recover (financially, mentally, and physically) from my front HP44. I could replace my steering stabilizer that everyone tells me to get rid of!
How long did it take to do it? Is it a day project.
-Avery
the throw of my tie-rod is actually right on at 8", I've got the steering stops set to hit at the same time as the ram maxes and that leaves just a little before the yokes contact.SeanP said:Brett, what are you doing to make sure that the throw of the ram doesn't exceed the steering stops? I know quite a few folks overlooked this and wonder why they are cracking their 44 and 60 knuckles. My high steer arms are shorter than most and for this reason I am thinking a 6" ram would be better than an 8" so I don't over throw the steering.
SeanP
BrettM said:the throw of my tie-rod is actually right on at 8", I've got the steering stops set to hit at the same time as the ram maxes and that leaves just a little before the yokes contact.
these rams are real easy to take apart if you want to add a spacer to shorten the throw, I think delrin would be a good choice for that job.
sure thing, I'll have at lease 3 inches of 1.5" Delrin rod left over from my 3 link project, you can use it to limit your ram if you like.SeanP said:Cool. Thanks for guinea pigging this stuff. I'll ping you when I get around to doing this project.
SeanP
jephs422 said:I'm getting ready to do mine next week. All of my parts just came in from the surplus place. Question for you guys though. WIll I need to pull my entire box apart if I do not plan on rebuilding it? Can I simply drill and tap, and clean clean clean......
You need to pull the box apart, but you don't need to pull the internals apart as much as Ashman did to replace all the seals and stuff.jephs422 said:I'm getting ready to do mine next week. All of my parts just came in from the surplus place. Question for you guys though. WIll I need to pull my entire box apart if I do not plan on rebuilding it? Can I simply drill and tap, and clean clean clean......
