:twak:
Troy, I can see how bad you want some bigger axles........but remember, you haven't broken the ones you have, yet. I should propably keep my thoughts to myself, but this discussion can apply to many people, so maybe someone will get something out of this.
I know all don't agree with me, so this is my way of looking at it. I don't like to do a modification that is supposed to be an upgrade, and then go backwards in other areas in the process. If I am upgrading one part, it has to be done in a way that doesn't detract in other ways. Let's look at what you're gaining, and what you're loosing.
You want a stronger front axle, so the D44. You're keeping high pinion, which is good, you're gaining gear strength, increasing axle shaft strength, housing strength, and gaining brake size. The most likely part to break, however, the axle u-joints or axle yokes, is staying the same, you aren't gaining anything. You are loosing some ground clearance, and loosing the ARB that you really like. You're going full width, which is a negative, since it will get into more sqeezes, and will have to climb some rocks and ledges that the narrower axle will miss. This slightly increases the possibility of breaking a front axle joint. You're loosing the four link and coils to leaf springs, which is also a negative. I realize that leaves work fine in the front, but they don't work as well as coils. They don't ride or handle as well either, and if this isn't a concern for you, it should be, and it definitely is there. The other big negative of front leaves is the axle wrap, that you don't get with a four link.
Now the 9" in the rear. It has great gear strength, but the D44 you now have isn't bad. The axles increase from 30 spline to 31 spline (assuming it's not a 28 spline 9"), which is too insignificant to consider as an upgrade. The pinion on the 9" is even lower than it is on the D44, which is definitely a negative. The full width is a negative for the reasons already stated.
IF you had stock axles, with stock gears and no lockers and were just getting started, and ran across those axles, it would be tempting to use them......if you are a full width axle kind of a guy. (BTW, full width used to be cool, but it isn't any more because it doesn't work as well) Since you already have gears and lockers in both axles, and a lift, it is quite a bit of a trade off in important areas. Personally, I would never make the change that you are proposing........it has WAY too many compromises and down sides for my way of thinking.
JMHO.....FWIW.
