Rawbrown
- Encinitas, CA
correction,
'89 with abs. any abs cherokee has 297's
ChuckD said:www.car-parts.com
Shafts usually run about $50-75 EACH SIDE + shipping, sometimes they have the hubs attached. Also look for later Wranglers (TJ's) and 91' and newer XJ's with ABS, XJ's after about 95' all had the larger joints.
Pick-in-pulls have them even cheaper, but you do the labor of pulling them off. Just make sure you have both the 13mm 12-point socket and a 36mm socket.
