HP D30 & 29-spline 8.25 w/ 4.10 gears
ehall
$900
These came out of my XJ last week. They were used for DD and trails alike. They were regularly maintained, all fittings were regreased with every oil change, and there are no fluid leaks. There is some rash on the LCA buckets and diff covers, and one of the rear shock mounts has a torn weld, which I can repair if desired.
High-pinion DANA 30 with 91-98 hubs/brakes
Riddler differential cover with LubeLocker gasket
Differential bearings and seals replaced a couple of years ago
SKF wheel hubs installed last year
Alloy X-Joint greaseable u-joints with full-circle clips
Undercover Fab passenger UCA bracket
Alloy tube seals
Coil buckets tapped for bumpstop retainer
Brakes were rebuilt a couple of years ago--will need new pads soon, rotors and calipers are still good
Includes a set of spare axle shafts with rebuilt OEM hub bearings
29-spline Chrysler 8.25 from a low-mileage 99 donor
New drums and shoes (few weeks old)
Hard lines replaced a couple of years ago
Includes a pair of spare axle shafts
Located in Lexington Park, MD. Will not ship.
I forgot to say that the D30 is already setup for over-the-knuckle steering with raised swaybar links and a fully-welded TRE flip insert. This will put your tie-rod over the axle out of harms way, but may require modification with stock 15" wheel and factory backspacing.
