Voteban
- Lehi, Utah
when you are braking them in, the 45-15 thing works, however, don't just stop on the side of the road to cool them down. drive it around for 10 or 15 minutes and try to avoid using them. if you have to stop, use the e-brake to hold yourself in place. don't just sit with your foot on the pedal.
I was told not to use them while they're cooling down, just to sit there and don't touch the brakes. I suppose driving around works too, it would probably cool them off faster. I didn't mean you should sit there on the brake the whole time though, just throw it in park and turn it off (or turn it off and put it in gear with a manual).
Most performance brake pads come with bedding instructions. They vary from company to company, so read the literature.
Do agree that a proper break in in crucial for maximum performance.
I've never purchased performance brake pads myself, if I do I'll be sure to read the instructions. I've never received break-in instructions with any pads / rotors.. Then again, I haven't purchased any, I've just helped install them.
My opinion is that your brakes never work as good as they can if you don't break them in properly. :thumbup:
