How to remove fuel injector clips?
jls095
MA
Hi all,
What's the trick to removing the electrical harness clips on the fuel injectors? I can't seem to figure it out - also don't want to pull too hard and break them.
There is indeed a special tool for removing electrical
clips. Cost is about 8-10 bucks, and well worth it for
working on modern vehicles, especially on FI connectors.
Some of the previous answers were based on earlier injectors.
1) Pull the red slide lock (if still there) up towards the hood. It might break off. Thats ok.. its not really needed.
2) You could push on the button, but with the age it is better to use a small pick. At the very bottom of the plug use a small pick to gently pull the clip up a bit.. like 1/16". While doing that pull the plug away from the injector.
You're the man, thanks!
