- Rainy side of Washington
The mileage on 97+ clusters is in the ecu and the cluster, stored individually and updated individually. You will need to have it updated or find one reasonably close to yours.
no one has to know you changed it lolGreat write-up.
Only legality there is with odometers is that you cannot change the reading for sale purposes. I have turned many back to keep info straight on some of my drag cars. I looked into that subject a while ago when doing it. But back on topic................ again nice write up
Okay so first of all thank you very much for all the information and all the pictures and everything, that helps a lot. But I have a kicker for you on my 89 Comanche which has the renix era Harness, the PO swapped and 06 Jeep Wrangler TJ 4.0 L engine which sensors do you think would work on mine? Or if anyone happens to know I would greatly appreciate it!
Thanks!
Well the information you need is that the 2006 PCM processes the oil pressure and temp readings and sends it via the can bus to the cluster. Unless you have the 06 TJ cluster and wiring swapped in then it might not work like you want. The 06 head does not have the temp sensor port for the renix era temp sending units.
This isn't really the right place for this question but I hope I gave you the information you need. If you have any other questions please start a NEW thread about your specific vehicle as this thread isn't about engine swaps.
Ok cool thanks for the info! And Sorry I didnt mean to mess this thread up
