Vanimal
- escondido, ca
more or less ready. just need to find a 17" 8 lug rim for my spare.
let me know when you're going to roll so i can get the camera out.Got frame stiffeners finally welded on this last weekend, need to finish up the new belly pan/crossmember, reinstall rock rails and and a few minor odds and ends and I'll be ready to roll.
Finish plumbing the rear brakes done
plumb ARB and install tank, plumb OBA to tank done
swap in new u bolts
Install front HP 9" done
Get prothanes dialed in done
drive 500 miles, change lube
install rear shafts
rear Dana 44 swap
front locker install
currie hd steering to be installed
rock rails to be built and installed
In following the usual tradition of listing work needed I'll start...
All I need to take the red Jeep is shocks and to fix the gaping exhaust leak I picked up on Swamp Lake. After that I'm ready go.
Maybe I'll even get it ready before the zero hour!
Fuel filter.replacedLeaky fuel filter
leaky fuel pump housing
leaky exhaust manifold
running hot
tires have seen better days.
Getting closer!
Newbie here.
Needed:
-Need to hook up and wire fixed antenna for the CB (anyone have tuning gear they can bring to help me dial it in?)
Hoping:
-Better support my track bar (single sheer BDS mount is already a little sloppy)
-Truss the hp d30 (have the pieces, just need to fit and weld it in)
-Cut/clearance rear fenders (maybe, I'm down to three flares already from rubbing on 32s)
-Decide whether I add a leaf and bastard pack it, or just throw a 5/8" spacer back there that I already have.
