McJesse
- Battle Ground/WA
Ok i kinda understand what your saying but i don't hahaha
Well first off. The best way to do it is work with someone who has the experience, time, and patience to help you out. Just crawl under your jeep and maybe just inspect it for a little while?... Get an idea on how the parts work together and what parts you have to replace the parts on the jeep.
Second, if everything you listed is indeed everything you have then you are short on some parts. You will need extended brake line, or just drop the stock brackets down. Atleast some sort of longer than stock lower control arms (these are the arms that keep your axle from moving forward and backward), if you dont replace them then you wont be able to adjust for proper caster very easily (caster is the angle your ball joints are in relation to the ground), it wont handle worth crap if this isnt correct, and you could get death wobble. I would actually invest in a long arm upgrade, a little bit more now but worth the money when you decide to upgrade later, 600 dollars is worth it... I would also ditch the blocks and spend 150 on a 3" add-a-leaf, especially if they are aluminum blocks.
Even though some people get annoyed, the best way to learn is ask questions. Now we have the internet, so it would always be recommended to do some searching and research on what goes into a lift.
Another thing to remember is to not be in a rush to go bigger. Take your time. You dont want to jump into something ready for. This goes for finding stuff for your lift. I waited months before I found the right deals for my lift that I pieced together.
Does anyone know where i can get cheap but good leaf packs?
what do you guys recomend?
I suggest 4.5" Leaf springs (rough country/Rubicon express etc etc)i think i'm just going to get rid of the blocks, sell those and then maybe just save the shackles but wont put them on and just get new leaf packs to put on the back and not ness around because of what i've heard blocks dont seem like a good idea haha.
Bastard pack to start out with. Cheap, yet effective. And you dont even have to screw around with removing the leafs from the rig.
