CanMan
- Lake Tapps, WA
Should of done some more research on a complete lift kit. Blocks are garbage especially at 3". 3.5" adjustable shackles sound like crap too. It'll have bad axle wrap, and ride like sh!t.
You'll need ALOT more than just lift parts to make it right, or even driveable.
Long arms or drop brackets
Upgraded LCA's and UCA's
Longer NEW u bolts
Extended brake lines
SYE and driveshaft(T case drop will do nothing for a late model rig if thats what you have)
Adjustable track bar and beefy frame side bracket
Steering(stock might work but will suck)
Other things
Im sure you'll be running large tires on stock gears, so mileage is going to drop through the floor, power is going to be lost, and your trans will get hotter than normal unless you run a large aftermarket cooler.
Good luck though.
Longer NEW u bolts
Other things
Good luck though.
