- In a strange land
The relay module for a winch is certainly subject to vibration if mounted to the bumper. How much worse is the engine?
I ask because this is too easy. It has to be wrong.
[FONT="]Remove existing bracket from relay box and reverse it. Everything bolts right up using the AC compressor bolt. The hole in the bracket is even the right size for the AC compressor bolt. However, I would probably drill a new hole 1/2" closer to the bend.
If this is such a bad idea I can probably fab up a bracket mount welded to the battery tray (Dirtbound), so this is not an option of last resort. It is just so easy.
And it keeps all the cables nice and short. Probably about 16" to the winch:
[/FONT]
