- Denver, CO
Allright, here's what I think is my final list of things to do. There's a couple of things left to order, a few things that may get bumped (front PIAA lights maybe), and a couple of variables but this is the list.
Power wash/Hotsy undercarriage
Remove Interior
Mock cage in
Remove rear wheels and put on tallest jack stands available
Remove rear suspension
Clean/grind areas for rear stiffners
Weld in rear stiffners
Tie in rear of cage to rear stiffners
Top Secret Coat rear end
Install rear rock lights
Install gas tank $1,100 http://genright.com/products/jeep-xj-extended-range-gas-tank-skid-plate-30-5-gal.html
Install rear suspension x? No lift?
BPE's Shackle relocations Shackles Leaves Axle Shocks
Install SYE and driveshaft
Remove front tires and place on high jackstands
Cut out rockers
Install rockers
Tie cage in to rockers
Install front frame stiffners
Install front crossmember stiffner
Coat with Top Secret
Install new steering box x
Install boostwerks steering brace
Install swaybar and swaybar spacer/poly mounts
Install suspension and MOCK UP axle
Coils Control Arms Steering
Mockup Axle and tack track bar bracket and swaybar brackets in place
Remove axle and fully weld it
Sandblast axle
Paint axle
Have dutch setup gears/locker
Assemble axle (brakes)
Install front rock lights
Install suspension, steering, and axle
BPE's Coils Control arms Trackbar Steering Shocks
Install tires
Install Hooligan fenders
Coat interior with Top Secret x
Install sound deadener
Wire in: Rear cube lights x
Rear hatch lights
CB Antenna x
CB
Rock lights
Apillar lights
52" curved bar x
PIAA's on front x
Lockers
Air compressor
USB ports x
Winch
Reinstall interior
Get new tires and wheels installed
Remove Interior
Mock cage in
Cut out rockers
Install rockers
Sandblast axle
Paint axle
Install tires
Rear hatch lights
CB Antenna x
CB
Rock lights
Apillar lights
52" curved bar x
PIAA's on front x
Lockers
Air compressor
USB ports x
Winch
Reinstall interior
