Hi Lift Farm Jack Under Rear Seat Pic?
I was going to say the only way for it to fit with out cutting or massaging is to disassemble. I used to store mine behind the rear seat with brackets made from some company. It was pretty slick but if you made a couple of cuts across tunnel then you could fit jack and axles and keep the hi lift in one piece
thanks for the photo. i assume you had to massage the tunnel a bit. is there any risk when doing this? i won't get chance to get to mine until later today.
I did this today and it is soo much nicer than having it in the back.
I just hammered the tunnel a little not much. I took the handle/jack mechanism (I have a HF Jack it is all one piece) off the I beam member. They both fit with all my other junk under the seat. The seat latches shut and everything is stored outta site.
I highly recommend doing this if you have a hi lift.
