OverlandZJ
NAXJA Member # 101
- Bristol,PA
Is that a rusty bolt on the cam sensor???
Bite me.. both of y'all.
nifty spot for the oil pressure sender, I forgot the wranglers have it over there... what are you gonna do for mounting the coil pack?
Bolt it right back on..
I'd take the leaves down, one of the best ways to pass time is to watch birds fly into bay windows :thumbup:
mounts should be there tomorrow, sorry I couldn't get them out sooner
Thats a daily occurance almost. The Mrs has her seed and nectar feeders close by as she likes seeing them. If i could only keep the squirrels from dumping them..
Thats fine, i appreciate the hook up Doug! Weather looks like everything will sit till friday anyway. Thanks again!
Cleaned up and ready to install...almost. All four motor mounts i have are cracked pretty good, i dont want to wrestle with them later so i'll wait for a new set. Was hoping to hear this run this weekend.. I'll just detail more than i probably would have.
Awesome! Great getting them started early.Teachin the stepson about painting. this is what we are starting with...
Showing him how to hold the sand paper
Nice Ken, you sure have a project in that house!Today I pretended to be a mason:
Aren't you NOT supposed to sand with you hand/fingers on auto paint type work. Block it man, block it.
Yeah, I was thinking more along the lines of ridges from your fingers and not a smooth sanding surface, but then again I'm not a body guy. :laugh:as long as you clean it before the paint is applied, to clean off the grease and everything. besides, this particular job is just temporary till i get another hood cause a PO cut vents into it, looks horrible, water dripping on all of the wires, then the guy i bought it off of took the vents out and put plates... i figured it was a good "get him interested" project
