Help replacing the turn signal arm.
riverside
Riverside CA
How do I replace the turn signal arm on a 92?
Not the switch, just the arm (see photo).
Do I just pull on it (as I was told)?
What about the wire that presently goes no where?
Thanks!!
Can't see your picture, but yes, it just pulls out. It takes a bit of a jerk and you want to be pulling nice and straight or other stuff will break.
The wire hanging out I'm assuming is for the cruise control switches, which if it's not plugged in...maybe you don't have cruise?
Great, thanks, Yes, I do have cruise control, but where does the wire(s) go?
1-QzQZTxHgKYpesl4Q2bD84jp0hE74ERL
Maybe this image will work, this is the part I bought.
Photo hosting is not on the site yet. It is being actively worked on though.
Okay, so you just pull out the old and put in the new? Where's the wire you're worried about?
The wire (I believe with two leads) is coming from within the steering column and looks like it somehow hooked up to the turn signal.
How do I activate the curse control?
I recently bought the vehicle used.
Thanks
If the new stick has no wire, and no cruise switch (as shown in the pic) then you got the wrong one. The one you have is for a vehicle without cruise control.
Somehow, that doesn't look like the arm for an XJ. Is this an XJ (Cherokee)? For a '92, it just doesn't look right.
David Bricker / SYR
