Red91Laredo
- Portland, Oregon
So I was changing my oil the other day and noticed that the oil was draining out really slow. I thought that was strange but it was pretty cold out and I had recently added 1/2 bottle of Lucas oil stabilizer to the engine so I didn't think much of it. Well, when I went to put the drain plug back in, I saw the threads of a bolt sticking out the oil drain hole. So I dropped the pan and this is what I found (see pics below). It's a small bolt about 22mm in total length and threads about 7.7mm in diameter. It doesn't look to have been broken off and isn't damaged in any way.
After removing the oil pan and shining my work light in every nook and cranny I can't find anything on the bottom end of the engine that is missing a bolt. Before I got the pan off I had a theory that it might be an oil pump bolt, but both of those bolts are still there. I don't know how large the oil galleys in a 4.0L are, but is it possible it came from elsewhere in the engine (valvetrain? timing set?) and made it down into the oil sump?
I don't know how long this bolt has been in my oil pan but I assume this happened within the last 3000 miles. I've done all the oil changes on the Jeep since I got it (I've put 25k on it so that's 7 or 8 oil changes) and I think I would have discovered it by now. Since the oil draining out was enough pressure to sweep it into the drain hole I assume that would have happened previously. There's no sludge in my oil pan (at least that's good news) so it's not like it was stuck in place down there.
The engine is running fine. I just came back from a 2500 mile road trip and it ran great. I'm afraid to fill it back up with oil and drive it until I find out where this bolt goes and replace it, obviously...
