johnsoninc86
- Bloomington, IN
So I have decided to upgrade the main charging wires underneath the hood to solve the voltage drop issues I keep getting. I need to do the alt. to battery, battery to chassis ground, and block to chassis ground. I've got 1/0 gauge to do it with, and a bar style 175 amp fuse. I already read through the link in the Tech/ FAQ sticky, and I pretty much understand it, but I still need a couple of questions answered.
1. Which wire is the output wire on the alternator that I need to piggy back over? Theres three or four connections on the back of the alt. So which one do I need to piggy back over, A, B, or C?
2. Also, should I A.) go straight from the alternator to the battery with the bar fuse or B.) should I go from the alt. to the existing stud on the front of the PDC with the bar fuse, then from there go to the battery like the factory setup?
