Any details on the 242 kits yet?
Got mine and put it on a while back.......lots nicer with all the stock bracketry junk out of the way.
Only complaint of sorts, is it would be awesome if the threaded rod worked like a drag link so that when it is turned, it lengthens or shortens the shift length, instead of having to take one end loose to lengthen it.
I hear ya completely. As we grow, we will look into getting turnbuckles machined. To make it affordable however, I would need to purchase a substantial qty. This will of course increase the cost of the kit as well.
We feel it isn't really a big issue either, as you should really only need to adjust the linkage once.
We had parts come back last week. I Just need to snap some pics and they'll be back up on the site. :cheers:
Has anyone noticed any Transfer Case shifter noise/vibration after installing the HD 231 Shift Linkage?
I had the occasional vibration noise from my Transfer case Shifter handle before the new linkage installation but post kit install I have consistent vibration that comes f/the TC handle. If I put my hand on the top of the shift handle when the I hear the vibration/noise it stops immediately and then if I remove my hand the noise returns. I've not took things apart to see if I could figure this out yet, but wanted to get others input?
Perhaps it's just the nature of the XJ, but it'd be nice to resolve this annoying noise/vibration. Thanks all
It may also simply be that the shifter needs taken apart and greased.
Awesome thank you!
I'll have it in the mail tomorrow for ya.
