Yes the bed tweaked alot. But it also has the entire floor cut out to allow the notched frame to come through it. And yes I did use a ramp to drive up on it cause I didnt want the whole bed to fold under the XJ weight. It does still run, and very well might I add. Its parked because the tranny cross member is being re-fabbed seeing how we drug through the previous 1 on the interstate laying frame and throwing sparks.
As far as the brake lines go I had both sets made at a shop cause the lines with the kit were far from long enough. I gave them to my buddy who has a 4.5" lift and figured they would be plenty.
Now burnouts? Ive tried to white wall the tires and the ass end hops really bad when it breaks loose. 1st time I pulled out onto pavement with the tires I lit it up and the ass end kicked out then the tires started hopping violently so I let out of it immediately!
