Harold of the Rocks
Well its 2x8 so cutting it like the second pic should leave me 6.75".
Im not going to bother with the winch provisions for now.
Thats why im making it bolt on for now. I just need some front recovery points for moab.
true dat. harder to put it back later
Iv been experimenting with pre-heating the metal with the torch for added penetration with my wimpy welder and I think its been working pretty well
as you can see from this terrible picture
getting there.
ok so here is my Moab to do list.
TO DO:
(in order of importance)
Change oil
DONE---Fix Xmember
Fix Hydro( just need to switch some hoses around)
ALMOST DONE---Front bumper (waiting on D-ring mounts from RS)
Exhaust(still dont know how Im going to do this.
DONE--Rear brakes
2nd Xmember/Belly skid
New King Pin washers
Install new Rad
Remove AC Condenser
2x6 Rocker
leaf spring bushings
Plastic windows
I can come up there early if you need a hand at all. Where are you putting plastic windows? Thought everything but the back hatch was intact?
sure come up when ever you want. It would be awesome to have someone who can actually do stuff help me.
and I blew out the pass side rear window at the last roctober fest.
if all else fails, trash bag windows are both affordable and stylish.
I looking for something that will stand up 70mph for 32hrs. Idk if mr. glad is up to that task.
I already replaces the side glass with plexy since the last post. now Im trying to get what lest of the glue and glass off the hatch.
up dated to show the stuff im not even going to try cause Im lazy.
TO DO:
Change oil
DONE---Fix Xmember
DONE--Rear brakes
ON THE FENCE---2nd Xmember/Belly skid
PROBABLY NOT---New King Pin washers
Install new Rad
Remove AC Condenser
NOPE---Pass side 2x6 Rocker
NOPE---leaf spring bushings
Plastic windows
You need better trash bags! This is all I use when working on the house: Www.demobags.com
ok so should I sink this d ring tab in further like in the second pic or leave it full length like in the first?
and yes its going through both sides of the tube.
update
TO DO:
Change oil
DONE---Fix Xmember
DONE---Fix Hydro(Yay I can turn right now!)
DONE---Front bumper (Paint and bolt it on)
Exhaust(still dont know how Im going to do this.)
STILL NOT DONE--Rear brakes( reflaired the lines but they still leak)
PROBABLY NOT---2nd Xmember/Belly skid
Install new Rad
Remove AC Condenser
THINKING ABOUT IT AGAIN---Pass side 2x6 Rocker
HALF DONE---Plastic windows
finished bumper-
I left the sides alittle raged because they are going to get cover by the tie in plates anyway.
