Do not cross the river. Monument creek is up over a foot. There are two possible crossings from Hackett Gulch. There is a cut off to the right 2/3 of the way down that goes down a rock slab with what looks like an old winch anchor in it. This goes to the crossing that connects to the trail that will eventually take you to the Longwater crossing and trail, with another crossing in between. I came out that first crossing a few weeks ago when I'm sure the run-off was way less, and had some water go over my hood crawling out the river bank. I'm on 33's and 4.5". If you don't take that cut-off, you will come down to a crossing that goes to a very nice picnic area at the base of widow maker hill, which last I saw was closed. That crossing, way back when I was on a couple of inches and 30's, I refused to cross when I saw a wrangler on 31's and 3" get turned sideways by the current and get hydrolocked. The XJ that went across was on 35's and probably 6", locked and locked. I'm guessing run-off will be considerable, and the river will be quite high. Myself, I wouldn't do it on less than 37's with a snorkel, but I am a conservative old bastard.
There will be snow in the shadows. There was snow in the shadows on Cedar Mtn road that were quite icey a couple of weeks ago. Most of the trail is pretty well drained, but there are tight, off-camber squeezes that will make minor body damage possible when slicky. The base of Hackett rock is very dug out. I went up when there was considerable snow pack with no problem, but wet, muddy rocks are a little different.
I'd expect the trail to be pretty sloppy. There is a climb after Hackett rock that I'd expect to be pretty muddy. It was interesting going down when it was dry, sloppy going up?? I'm not going, my front driveshaft has a bad u-joint that would survive an average 4wd outing, which Hackett is when dry, but I don't trust it if I had to stress it. I think it's just going to be too sloppy for me. Led is out also.
20 years ago it was $500 to be hauled out of there by a bull dozer, I'm sure it's a few grand now.
