Nealio240z
- Redding, CA
Just ordered a full set. THANK YOU!!!!
Just got mine. Shipping was fast. What do you suggest for prep between plates and frame? I haven't heard to much good about weld through primer. I was thinking some self etching primer on back of plates and frame, mark where I will weld and remove primer there.. Any suggestions?
I clean everything off the frame rails, weld the stiffies in place. Prime and paint the snot out of them. If you live in a nasty climate spray down the edges real good with undercoating.
no worry of corrosion between plates and frame?
