Today was a "little stuff" day, and it was kind-of tedious, since I was making it up as I went.
Started with some shade-tree adaptations to make the e-brakes work -- worked great, but coincidentally (?) my lever seems to have gone kaput after testing. :gag::
Then it was time to work on the actual brakes - passenger side I used the stock WJ line, both hard and soft, but had to caress the soft side/caliper mounting point since the JK calipers use a slightly larger banjo bolt. No biggie, it took a little time and patience, but I got er done:
Driverside, I ended up using an old Chebby/Waggy front brake line I had from my Waggy D44 conversion on the XJ - worked great, along with a new RE extended mainline and some homemade bracketry:
I salvaged the shock mounts (again) and got the passenger side completed:
The rear is at actual ride height now, the front has 2" of lift on the way to get out of the stinkbug stance:
I'll have to have a miracle type of week if I am to meet my goal of wrapping it up next weekend... :cheers::farmer:
