do yourself a favor and gusset the loop on that rear axle. maybe you already plan to, but i have seen a lot of those upper links tear off just being welded on the tube
I was considering a bolt-on gusset to the diff cover -- and I thought the same thing... the guys at Claytons said they have only heard of such damage in "extreme" situations and rarely then. I'll try and think about the best way to gusset!
So, my Clayton rear LCA's are extended to, and perhaps beyond, their safe length, and my tire is still about 1" too far forward in the wheel well. This is due to the JK LCA mounts being lower than the axle tube, and in fact slightly behind the centerline, whereas the WJ stock LCA mount location is slightly forward of the axle tube -- about a 2" difference. You can kindof see it here:
So I'll be grafting some new LCA mounts on, at axle tube height and in front of the axle, to shorten these arms up by around 3", and give me the ability to safely push the wheel back to the center, and a bit beyond... hopefully this weekend.
The front is currently sitting about 1.5" lower than the rear, so today I ordered a 2" spacer for the front and a 3/4" spacer for the rear, to gain a little extra altitude and even out the stance. I doubt I'll get as much done this weekend as last, but I'm gonna keep hammering away! :guitar:
