Fullsizexj
- Milton WV
It was just a matter of what I wanted to use it for at the time and what I want to do now has changed, so stripping it down makes sense for the reasons I have
Goatman said:Granted, a weld can break or a bar can bend, but that corner still has considerable structural strength even though it doesn't have a diagonal going to it from the opposite B pillar. I agree that it would be stronger with it's own diagonal, but it should still be strong enough.
Fullsizexj said:for the Radiator, we are gonna run Hrew tube underneath to each end with regular flex hose for the connections on each end, this way I can get a hose anywhere if ever needed, some get that custom long hose and run it from end to end but try and find it in an emergency when you need it
FarmerMatt said:I disagree. That diagnal in the roof would only help on a side impact not in a complete turtle manuver. The only structure that corner has in a turtle move is the bar from that corner to the rear.
Goatman said:Is that clear enough?![]()
FarmerMatt said:Nope. There's simply to large an unsupported span across the top of the "B" pillar IMO. It wouldn't take much for the top of the "B" hoop to bend & as it does would pull the "B" pillar in towards the passenger. I guess we'll agree to disagree.
:twak:
:cheers:
Matt
Fullsizexj said:yeah but that are all mud, kinda defeats the purpose but I will see what I can find anyways
Lincoln said:Matt,
Trying to understand you a little
FarmerMatt said:Many have tried, but none have succeeded...:conceited
My main concern is the passenger. I believe the cage is weak in the corner above the passengers head. Imagine if (IF) the "B" hoop bent down in that area, there is not enough bracing to keep the "B" pillar area from being pulled inward towards the passenger at the same time. By simply finishing the "X" into that corner you'd have it braced extremely well & it wouldn't add more than a couple pounds to the build. I feel it would make the difference of only having to fix a bent tube after a roll than having the entire passenger "B" pillar tweaked after a roll. Again this is my opinion I the rest of the rig is very well built IMO...
Honestly I doubt that we'll ever really know if it'll hold up because this thread & build will end up just like this one, that's it I'm going Rockwells :firedevil Always the bridesmaid & never the bride...:laugh3:
Matt
