Jeff 98XJ WI
- Butternut, WI
I really don't understand the theory behind the construction of these manifolds. Let me try to explain the construction. It seems like they have a plate that bolts to the head, four short tubes welded to this, then the two halves of the inner piece installed over the short tubes and welded to the tubes. Then the two halves of the outer installed over the inner and the short tubes and welded around the tubes. There is a ring of fiber material between the inner and outer pieces where they join at the collector. Finally, the curved tube is welded to the junction of the inner and outer at the collector. The inner has two open slots per exhaust outlet that allow at least some gas to pass between the inner and the outer and two open slots where the inner and outer meet back at the collector. Here are a couple pics of the slots by the exhaust outlets.
I think I'm just going to tack the inner to the outer at my cut line, reinstall the outer at an angle for frame clearance and then weld the tube to the outer collector at an angle that works. Jeff
![P1010451.jpg](/proxy.php?image=http%3A%2F%2Fi193.photobucket.com%2Falbums%2Fz94%2Ffourliter%2FNew%2520MJ%2520engine%252003%2520five%2520point%2520three%2FP1010451.jpg&hash=7b90e540b45ba0c688caa02b1c3dee8b)
![P1010452.jpg](/proxy.php?image=http%3A%2F%2Fi193.photobucket.com%2Falbums%2Fz94%2Ffourliter%2FNew%2520MJ%2520engine%252003%2520five%2520point%2520three%2FP1010452.jpg&hash=79bbbe2ec3b216106ae7a99f7a4ab398)
