Here are a few shots of the install of H.D. Offroad Engineering's new frame stiffeners...
Made from 10 ga. steel, CNC cut and punched for plenty of rosette welds.
Clean the frame well to prep for welding. I found a 24 grit sandpaper flap wheel works best for the undercoating, which is still a pain to remove. Make sure you go up past the rail on the bottom of the floor also to stitch the top of the stiffener to the unibody.
Loosen the crossmember bolts enough to slide the stiffener above it (~3/16").
Slide the stiffener into position.
Start at the front and cinch the stiffener snugly against the frame using a large c-clamp. Then use a floor jack to push the bottom against the frame and tack weld as you move back. (In this picture the front has already been tacked and the jack and clamp have already been moved back).
Once it's tacked where you want it, finish welding. Fill the rosette holes and stitch weld around the perimeter of the stiffener on all edges.
The finished install. Afterward grind the welds smooth (optional) and prime and paint to prevent corrosion.
