- Billings MT/Rapid City SD
Well it seems my fuel pump has died again. After sespecting the engine was not getting gas I pulled the filter, let the gas drain then put the key in the on position. This should cause the pump to prime and spray gas out of the filter, correct? No gas comes out except when you lower the filter and it starts to shipon out. To rule out a clogged filter I removed the filter and ran the same test with the same results. Is there anything else that would cause the fuel pump not to run? also I just replaced the pump two years ago and I think it should last a bit longer and even the one I replaced only lasted 4 some years before this current one. So what are some good quality fuel pumps that are going to last a bit longer? I beilive both of the last pumps where from Napa.
