A asatxj NAXJA Forum User Location Grant, Michigan Sep 24, 2003 #1 Will a failing regulator cause poor running/mileage? Mine is bad and despite new tuneup parts etc it's running rough and I've dropped a couple mpg.
Wayne Sihler NAXJA Member NAXJA Member Location Maurertown,Va. Sep 24, 2003 #2 While it may cause the problems you describe,I would look to replace the O2 sensor as that WILL cause that problem. Wayne
A asatxj NAXJA Forum User Location Grant, Michigan Sep 24, 2003 #3 O2 is on the list to PM but it needs fuel to run so I can go buy the O2. It'll happen later along with brakes,axle seals,body repairs.........
