- Santee, CA
Dana 44 Axle, XJ spring perches
Drums & backing plates with all hardware(parking brake cables and metal brake lines not included)
Two sets of factory axle shafts(2 Left, 2 Right)
Open carrier with 3.54 ring and inion
U-Joint yoke
Factory shock mounts have been removed by previous owner, I am including a set of RuffStuffSpecialties shock mounts. They need to be welded on.
This axle is not drop in ready, the carrier, ring and pinion came out of another housing, and therefore the pinion depth cannot be guaranteed to be correct nor are any bolts currently torqued to spec. This is a core for you to use when building a new axle for your rig.
$250.00
Located in Santee, CA
phone#619twofourfour9215
U-Joint yoke
$250.00
